FishOnOne wrote:
transamz9 wrote:
I'd like to see how the HDPP would stack up against a regular cab 2wd 6.2 or 6.4 250/2500 as far as quickness, towing and fuel efficiency.
The Ecoboost will outperform both 6.2/6.4 plain and simple
Quickness, Towing power, unloaded fuel eff., yes. Towing Fuel eff. would be a toss up.
Payload, is would come up significantly short.
Throw the Diesels for those 250/2500's into the mix (And lets face it, price point that's where the HDPP comes in), and the 150 will come up short in most. Quickness, (60 -80 to pull out an make a pass) I don't think those who praise the Eco, have experienced unleashing 900+ torques. Unloaded fuel eff., is probably pretty close in normal driving, with the periodic regens of the filter pulling the diesels numbers down to give an advantage to the Eco, but loaded, the Eco is not even going to come close. As for payload, the 250 with the diesel, and the 150 HDPP are neck and neck (2300-2400).
One common item I keep seeing brought up is the unloaded ride quality. Yes, its subjective, but two truck with nearly equal payloads, are going to react very similar over bumps in the road.
As for the hitch capability, it was said the HDPP is good for a tongue weight of 1300 (I assume this is its WD rating) the 250 with the heavy tow package is good for 2100 (Both carrying and WD).
