- transamz9Explorer
1jeep wrote:
Honestly I don't hate the new fords, but don't love them either. the only thing I have seen that I liked was the new dash and bigger sun roof, aside from that I will keep my antique 2016 model for a few more years.
What's funny to me is everyone around here that are ford freaks are raving about the new dash. Looks to me like ford just copied from ram. My 2013 had that same dash as does my 2016. Lol ford pushes that they went all aluminum to make lighter and stronger when they still have the heaviest truck of the three and just now caught up with the strength. Other than their dually they don't have any payload in their 350'system because of a pitiful gvwr. - 1jeepExplorer IIHonestly I don't hate the new fords, but don't love them either. the only thing I have seen that I liked was the new dash and bigger sun roof, aside from that I will keep my antique 2016 model for a few more years.
- 4x4ordExplorer III
Bionic Man wrote:
4x4ord wrote:
I tow an RV as well as haul all sorts of equipment or other "stuff" on a tandem dually gooseneck. Any 22000 lb RV will tow easier than the equipment they towed behind the 1 tons. When they are only travelling 45 mph and going up a steep incline with 30,000 lbs GCVW the wind resistance is a very small part of the equation. The wind and rolling resistance combined at 45 mph is not going to require over 80 hp to overcome where as 287 HP are required to lift a truck and trailer up an 8% grade at 45 mph excluding wind and rolling resistance. So a total rear wheel HP of 367 rear wheel HP would be required for an 8,000 lb truck to tow a 22000 lb rv up an 8% grade at 45 mph with only somewhere around 35 of that 367 Hp being used to overcome wind resistance. At 65 mph more like 90 Hp is required to overcome air resistance.
I don't think you are correct on this. I know from experience that my 2012 will not tow my 12,000 pound fifth wheel up Eisenhower (eastbound) and maintain the 60 MPH speed limit. My buddy has a 2013 or 2014 F350 that will not tow his 5er up at the speed limit either.
Seems to me that the tests I have seen FLT tow similar weights, they are able to maintain 60 MPH (or even accelerate). Wind resistance must play a significant role.
There are some errors in my calculations, for instance if the HP to overcome air resistance is 35 HP at 45 mph I should have come up with a HP requirement of 73 HP at 65 not 90.
With the FLT test for the 1 tons,wind resistance would be quite insignificant because the speed going up the hill was only about 40 miles per hour. Pulling my 16000 lb rv I get about 10 mpg where as towing a 20,000 lb gooseneck equipment trailer I get about 7 mpg. Even though a RV has a large front it still catches far less wind than a piece of equipment plopped on a gooseneck. larry barnhart wrote:
Sorry for not agreeing and not against a ford truck but poor mileage for that tow.
chevman
No need to be sorry my friend... :B- larry_barnhartExplorerSorry for not agreeing and not against a ford truck but poor mileage for that tow.
I would not be happy with that fuel mileage towing that low trailer.
chevman
x2. Where are the savings from the aluminum body?
The weight savings went back into the frame, drivetrain, brakes, to name a few.
Towing just got easier...- blofgrenExplorerI get a solid 10-11 mpg towing my 16k lbs high profile (13' 2" height) fifth wheel with my '13 CTD. This is hand calculated.
- goducks10ExplorerHeck I get that towing my 9000 lb 5th wheel with an old dinosaur 12 Ram CTD. In fact I usually get better than that.
Jewel? Nothing impressive about 10 MPG towing that trailer. - blofgrenExplorer
chevman
x2. Where are the savings from the aluminum body? - larry_barnhartExplorerI would not be happy with that fuel mileage towing that low trailer.
chevman
44,056 PostsLatest Activity: Jan 12, 2020
