- SoCalDesertRid1Explorer III'm no fan of air bags. If one fails though, it's not the end of the world. Empty the air from the other one and continue on down the road until you can replace the broken one.
larry barnhart wrote:
What I see at our winter resort is both Ram and Fords have sagging rear ends when they arrived to check in.
chevman
But when one of those air bags fail, the sagging will be the cause of being stranded on the side of the road. And yes they will fail!- larry_barnhartExplorerWhat I see at our winter resort is both Ram and Fords have sagging rear ends when they arrived to check in.
chevman - Cummins12V98Explorer III
SoCalDesertRider wrote:
When the truck is squatted down below level in the rear with the load, you get wallowy steering, poor braking and headlights blinding oncoming traffic.
If a truck is loaded under it's GVWR and RGAWR, the truck should not be squatting below level in the rear, if it's suspension has been properly spec'd by the manufacturer to carry it's full rated capacity. Therein lies the problem. They don't spec the springs to carry the full load properly (level).
Hopefully you're right and Ford's new 450 pickup springs won't be sagging anymore. Knowing Ford, I'm not holding my breath.
Kinda sorta what I was saying. - Cummins12V98Explorer III
taken wrote:
Incorrect but whatever... What always cracks me up on this forum is you are the most vocal and opinionated person here and yet have so little actual knowledge and theory. It's absolutely hysterical to read the drivel you post with such authority. Then it gets old and I don't read here for a while. Sure enough, when I come back, nothing has changed though. Why don't you post some more pics. I haven't seen your hitch in a while. LMAO...
Tell me what I said is not true - SoCalDesertRid1Explorer IIWhen the truck is squatted down below level in the rear with the load, you get wallowy steering, poor braking and headlights blinding oncoming traffic.
Hopefully you're right and Ford's new 450 pickup springs won't be sagging anymore. Knowing Ford, I'm not holding my breath. - takenExplorer II
Bedlam wrote:
I visit RV.net for the pictures...
Good point...LOL. I think I've had my fill for the summer. You all have fun. Fish, keep the faith... or come home to FTE before your brain explodes... Unsubscribing now... - BedlamModeratorI visit RV.net for the pictures...
- takenExplorer IIIncorrect but whatever... What always cracks me up on this forum is you are the most vocal and opinionated person here and yet have so little actual knowledge and theory. It's absolutely hysterical to read the drivel you post with such authority. Then it gets old and I don't read here for a while. Sure enough, when I come back, nothing has changed though. Why don't you post some more pics. I haven't seen your hitch in a while. LMAO...
- Cummins12V98Explorer IIIWhen a truck sits LEVEL with a big load the truck is doing what it's advertised to do. When the rear is BELOW level that is not so good.
Too many people think they need to have the truck ride with the same stance loaded or unloaded. Then they drive around with the TV rear high and the RV nose high, they they complain about ride quality.
The rear air ride in alt ride ht on the 3500 RAM's do ride nearly level loaded or un loaded.
44,065 PostsLatest Activity: Apr 12, 2026
