sgfrye's avatar
sgfrye
2017 Ford F-250 review
I'm posting this review because I own a TT and just bought new truck. I have towed many thing over the years from boats to TT's. wife and I bought a 33 foot TT ABOUT 4 months ago I've been towing with a 2000 f150 with factory towing package including transmission cooler. I'm guessing loaded for camping TT is about 8k lbs. specs say I'm overloaded probably have never been on DOT scales and don't plan on it. Been passed on hwy by many highway patrol and they never even noticed me. WDH hitch and sway control made towing easy and never felt unsafe for 1000 plus miles. but I have been wanting to upgrade trucks. Last Saturday I bought a commercial f250 superduty 6.2 gas v8. Hooked up today to take a test spin. **** what a difference. Suspension- hooked up and suspension did not sag any. Zero. Rear end felt like it was on a rail. Winding Country roads never felt any swag. Highway speeds 60 mph I'm turning 1200 rpms. On hills I babied the gas pedal and 2000 to 3000 rpms it feels like engine is screaming and underpowered. Get on steeper grade long hill pushed throttle to 3500 rpms and rig took off like a rocket ship. Power band is in that rpm range for sure. Overall mpg was 15.5 .mpg. If you can afford a diesel either Ford, chevy or dodge by all means buy one you won't regret it. I can afford 10k to 12k more for a Diesel engine and I don't see us buying a 15k pound 5th when anytime soon. If you want to upgrade a truck consider a f250 super duty.
  • MFL wrote:
    You have made quite an upgrade with your new 250, glad you are enjoying it! One suggestion I will offer, as to towing at 60 mph/1200 rpm, is to lock out 6th gear. The 6.2 will be happier towing closer to 2000 rpm, and may even get a slight increase in mpg.
    Jerry
    yep you nailed it.. it does tow better at 2000 rpm on flat land
  • You observed the night vs. day difference between F150 and F250.
    If buying a truck for towing, I suggest always get the F350 for the additional payload capacity. Price difference between F250 and F350 is minimal.
  • You have made quite an upgrade with your new 250, glad you are enjoying it! One suggestion I will offer, as to towing at 60 mph/1200 rpm, is to lock out 6th gear. The 6.2 will be happier towing closer to 2000 rpm, and may even get a slight increase in mpg.
    Jerry
  • Did you say you got 15.5 mpg while towing with a 6.2 gas? Are you sure? I have never seen anyone getting above 14 not towing anything.....
