Will a 2017 Ford F150 V8 with all the towing goodies handle my cougar XLite 5th wheel. Dry WT 6964, GVWR 9990, Hitch WT 1190. Will this truck with 4 wheel drive and 6.5 bed work? Thanks
It depends on your available payload, and RAWR/tire max rating. If you look on your driver door panel, a tire loading sticker will say weight not to exceed xxxx lbs, including all passengers gear, plus loaded hitch wt of FW, and hitch. I'm thinking pin wt of that FW loaded to camp, will be 16 to 18 hundred lbs.
I think your truck can tow the weight, but may not be able to carry the total payload. Not enough info given, to give accurate advice.
