- trail-explorerExplorerI still haven't seen them showing up on dealer websites as "incoming inventory" or the like.
One curious question... to the person that apparently works in the factory...
Are Sierras and Silverados built on the same assembly line? - gattorgetterExplorer
mich800 wrote:
deltabravo wrote:
gattorgetter wrote:
Well the front end is a bit different behind the griile, getting part changes established. Anytime there are changes it takes a bit to fix
what do you mean by "fix"?
"fixing" something implies there's something "wrong" or "broken"
Not really something wrong. Just fine tuning the assembly process. I assume that is what he is referring to. This is the case for every vehicle when there are changes.
This, - mich800Explorer
Not really something wrong. Just fine tuning the assembly process. I assume that is what he is referring to. This is the case for every vehicle when there are changes. gattorgetter wrote:
"fixing" something implies there's something "wrong" or "broken"- gattorgetterExplorerWell the front end is a bit different behind the griile, getting part changes established. Anytime there are changes it takes a bit to fix
gattorgetter wrote:
Its a slow ramp up until all kinks are worked out.
What kind of "kinks" are there?
The truck is essentially the same other than a all new Duramax and stuff under the hood. - gattorgetterExplorerJust started production on halloween, so first ones out the door were late monday night. Not all colors are running yet. Its a slow ramp up until all kinks are worked out.
- trail-explorerExplorerIt just went in to production last week or the week before, so it's going to be awhile before they hit dealer's lots.
- FxfymnExplorerI don't think so. The last I saw it was coming out in January.
44,056 PostsLatest Activity: Jan 12, 2020
