Cummins12V98 wrote:
I can't emphasize enough to stay away from LS!!!
Sorry you had a bad experience (I'm guessing).
All the stores are run independently. Most of the them do good work. Though I agree not all.
I found a good one, and have stopped buying tires and shocks anywhere else.
I had them replace my coil-airbags as well, since I didn't have the time. The price may not be the cheapest on that kind of work, but the warranty is better than anywhere else.
To the OP - the coil airbags work fine for lighter load-leveling. On my front end, they're good for about 1,500 pounds. Might be a little more on your truck since the coils have a slightly larger internal diameter. But if you're looking for thousands of pounds of load-leveling, outboard airbags would do better (at the expense of restricting suspension travel in most installs. I'm not familiar with the specs on your coil suspension setup).
