blt2ski
Jul 04, 2021Moderator
Replacing the coil springs is another option, assuming brakes and axel can handle the additional weight too!
Not sure where you are at, but usually in most major cities, there is a spring shop that can replace you current leaf/coil springs with a higher capacity amount, or one that is stiffer as you compress the setup. I've done this on a few trucks int he past with great success.
marty
marty
