ticki2
Jan 13, 2020Explorer
Wy4x4 wrote:That approach has some merit . Find a cab/chassis with the narrow rear axle for more clearance . Put a flatbed on it for tons of storage . As far as diesel lowering payload , it actually helps . Almost all the TC weight is on the rear axle which is the same for gas or diesel . Hardly ever is the front axle capacity used . The diesels extra weight in the front helps balance a loaded truck .
Thanks for the responses. This is very unfortunate as I custom ordered our truck from the factory, it is one of the last real trucks per-se (vinyl floor, manual trans, manual 4x4, etc). Could have easily got a 3500 at that time. It's hard to swallow that it pulls our heavy older 2002 3 horse gooseneck with 3 horses in it beautifully but can't handle a slide-in.
But it's OK, I am a mechanic. Maybe the best thing to do is find an older 3500 dually, build it up as an overland style rig, and be able to leave the camper on it all the time. That way when we go into the backwoods I won't cry if the truck takes a scratch.
44,070 PostsLatest Activity: Jul 21, 2026
