MORSNOW
Jan 13, 2020Navigator III
Wy4x4 wrote:MORSNOW wrote:
I have a WC850 on my 2500 GMC, the fully loaded wet weight including all of our camping gear is 3,200lbs.
Do you have air bags or any other upgrades to your truck?
After using it completely stock a few weekends, I added lower Stable Loads. They are incredible, keep the truck level and prevent side to side sway by including the overload spring into the equation all the time. I also tow a 16' trailer with a SXS on it so I added Timbrens later. The Timbrens are just above the axle most times and just assist when I load up the front of the trailer with a row a gas cans and firewood. No need for airbags with a non-slide camper and I don't want the sway/bounce of bags with all of Alaska's curvy mountain roads. A heavy spring is better for stability, that is why Super Springs, Stable Loads, and Sway Bars are preferred.
