Bedlam
Jan 14, 2020Moderator
The biggest draw back of the Ram 2500 is the coil spring placement. With the coils so far inboard, it is hard to keep a tall CG stabilized. You can add heavier coils, Timbren/Sumo springs farther outboard, a heavy stabilizer bar and heavily damped shocks along with higher rated tires and rims to make it better, but still will not be as good as a truck that has the primary suspension farther outboard. My opinion is that you can drop some money in this truck to make it an acceptable handling ride but it will never be exceptional with a truck camper.
Have you considered upfitting your current trailer so it can handle boon docking better? Perhaps a suspension lift, larger wheels, shocks and skid plates covering the bottom vulnerable components would be enough rather than having two campers or replacing your current one.
