Wy4x4's avatar
Wy4x4
2018 RAM 2500 with Adventurer 910DB
Looking into the purchase of the 910DB from Adventurer. This model suits our needs down to a T, has all the features we are looking for. But will our truck handle it? We have a 2018 RAM 2500 crew cab long bed with the Cummins engine and 6 speed manual transmission. Never owned a slide in truck camper before, looking for advice. The dry weight as advertised on the website is 3373 LBS, and most websites list an estimated wet weight of 4400 LBS. Google says the 2018 RAM 2500 payload is 1,466 to 3,497 lbs.
We like the 910DB for it's electric bunk option over the dinette, 4 season rating, king size bed, ample storage, and dry bath. I have not found any other truck campers with all those options and a single slide.
Thanks!
  • IMO - NO! Dry weight of 3373 and that is without any options such as battery, AC, etc. Add water and necessities and you will be looking at a camper weighing over 4500# when ready for a trip. I wouldn't even try to carry that on my 3500 SRW.
    You will need to stay with a very light camper, preferably non-basement. First your diesel eats up a lot of payload. Second is you have coil springs which is a double strike because it has coil springs AND they are mounted inside the frame rails. Neither of which work well for carrying a high COG item like a truck camper.
    What would be a better thing to do is upgrade to a DRW 35000 and then get the 910DB if that is the camper you think suits you.
