FishOnOne wrote:
So said another way average HP has been increased. With a new variable geometry turbo, increase boost pressure, and increase fuel flow, HP had to have increased somewhere.
New turbo? I didn't read anything about a new turbo. The 6.7L Cummins has had the same HE351VE turbo since 2007. They just increased boost limits.
I believe stock is only around 28-30 psi or so max( not 100% on that) before which is rather conservative. In contrast, my 513 hp tune pushes max to around 38 psi. However, due to the size of the turbine housing, the turbo looses its breath and becomes inefficient at higher pressures causing high EGT's. The HE351VE was made for quick spool and efficiency at lower rpms, not to be a high horsepower turbo.
Yes, if you increase torque at a given rpm then you will increase horsepower at that rpm as well. If the previous was 900 lb-ft at 1,700 rpm, doing the math ( 900 x 1,700/ 5,252) it was previously making 291 hp at 1,700 rpm. Now with 930 lb-ft at 1,700 rpm, it is making 301 hp at 1,700 rpm.
