bradmarco's avatar
bradmarco
2018 Yukon Denali 4X4 vs 2018 Yukon Denali XL 4X4
Hi All,
I am at a point where I just can't decide on my new tow vehicle. I have a 33ft 2016 Radiance TT with a 6700lb dry weight. I currently tow it with a 2013 Tahoe 4X4: Vortec 5.3L V8, 320hp, 335 torque, 6-speed auto tran, wheelbase 116in, two capacity of 8300. I also use a weight distribution system. I find that this vehicle tows the TT pretty well, but could definitely use a some more power. Therefore I am in the market for a new tow vehicle, but could use some insight / recommendations from anyone with experience. The 3 vehicles I am considering all have the bigger 6.2L V8, 420HP, 460 torque, new 10-speed trans. YD 4X4 has towing capacity of 8200lb and 116in wheelbase. YD XL 4X4 with tow capacity of 8000lbs and wheelbase of 130in. One main question is will the longer wheelbase be a noticeable benefit from a towing perspective? If so, another option would be the 2X4 XL gaining 300lb of tow capacity (8300), but really don't want to give up the 4WD as I am so accustomed to having it available. Lastly, I have juggled the truck option, 2500, but really weigh toward the SUV side on a day-to-day basis and only towing 1-2 times per month within 4-5hr radius. But, if the truck is the way to go and tows that much better, I'm willing to consider, especially because i am planning much longer (7-14hr radius) trips once per year. Any thoughts or experiences, especially if you currently tow with either of these vehicles and can provide pros and cons, would be greatly appreciated!!
  • Wheelbase will help a bit with stability. But as you saw the tow rating is lower since the truck weights more.
    If you are happy with how your current Tahoe handles the trailer, either should be an improvement with the 10speed and 6.2l. Just make sure you get the tow package for the cooling improvements.
  • fx2tom, manual reports hitch weight of 800lbs and using the Husky Center Line weight distribution w/sway control
  • A 2500HD truck will, without a doubt, tow better. What is the tongue weight of your trailer once loaded? The dry weight doesn't mean a whole lot.
  • Apologize, TT weight incorrect above, dry weight is 5420 and GVWR is 7640
