badercubed's avatar
badercubed
2019 Apex Nano Slide Leak
I have a 2019 Apex Nano 208BHS.
The slide appears to be leaking only when closed as under the dinette towards the rear of the slide was considerably wet. There does NOT appear to be the same issue when its closed. When parked, the slide is on the south side, which is typically not the "weather" side of my property and is protected by a barn on the north side.
All the seals and gaskets look great and there is nothing out of the ordinary when it's closed or closing. I shined a high powered flashlight around when closed and open trying to see if I could see something and nothing. Roof of the slide and TT all are solid and all of the caulk looks great.
I am going to have my wife spray a hose on it and look from the inside to see if I can see something, but wondering if anyone had anything similar happen that it could be something dumb.
1 Reply
  • Maybe water from the top of the slide when brought in while raining or wet? I’ve gotten that a couple times.
