Busdriver
Nov 21, 2020Explorer II
2019 Duramax Regen
If you have a L5P Duramax Don’t let them do the update for regens, mine used to to 4 to 6 hundred miles between regens, after the recall now 2 to 3 hundard miles
ktmrfs wrote:
duramax will also go to high idle in neutral during a cold start on cold days to help warmup. RPM will go to somewhere between 800-1000 IIRC, grid heater stays on, turbo goes to max backpressure and throttle valve is activated. All this to help warm up.
