- Grit_dogTrailblazer
mkirsch wrote:
I find that a lot of these types sit there and wait for you to email them back or give them a phone call with the answer.
Well I don't have his email or phone number, and don't want it, so...there's that. - mkirschNomad II
Grit dog wrote:
This is one of those "makes ya wonder" threads. OP posts a rather basic/cryptic post asking for help/suggestions, then doesn't return, even though it appears to be an immediate type of issue.
Could be....
DEF injector
DEF pump
DPF or SCR plugged
Malfunctioning sensor on exhaust, EGTs or O2s
Bad DEF sensor or bad DEF
Drives like an old man and plugged 'er up and hasn't spent any time completing a regen.
Physical issue with DFP or SCR
These off the top of my head. Bout as good as suggestions as can be given with literally no additional info provided by the guy with the constipated exhaust!
I find that a lot of these types sit there and wait for you to email them back or give them a phone call with the answer. Grit dog wrote:
Could be....
DEF injector
DEF pump
DPF or SCR plugged
He probably traded it in for a truck with a gas engine.- Grit_dogTrailblazerThis is one of those "makes ya wonder" threads. OP posts a rather basic/cryptic post asking for help/suggestions, then doesn't return, even though it appears to be an immediate type of issue.
Could be....
DEF injector
DEF pump
DPF or SCR plugged
These off the top of my head. Bout as good as suggestions as can be given with literally no additional info provided by the guy with the constipated exhaust! - sayoungExplorer
ACZL wrote:
Based on OP's post, I'd place $$ that the DPF (Diesel Particulate Filter) is plugged up
There is also 2 oxygen sensors , one on each side of the DPF filter if like my 2012. - Cummins12V98Explorer IIIAuto Parts can look at your codes.
Curious do you do a lot of short trips? - ACZLExplorerBased on OP's post, I'd place $$ that the DPF (Diesel Particulate Filter) is plugged up
- ksssExplorerIt should have at least basic Onstar. It will tell you what the code is.
- Michelle_SExplorer IIIMany Auto Parts Stores can read the code and give suggestions. Might be something simple or major, but the code will help.
- Grit_dogTrailblazerIf I had a truck with Tier IV emissions, I would not leave home without a good code reader. Something like AlfaOBD or similar.
44,070 PostsLatest Activity: Aug 07, 2026
