Ralph Cramden wrote:
pbeverly wrote:
Finally had time this past weekend to pull out a ladder and study the situation. Where the water was coming down is where the two gutter pieces meet, and there was a gap. Put a little sealant in there so this should take care of the problem and the water should travel down the gutter. Will probably do the other side as well after I close the slide out back up.
Good Luck. What you will find next year is the chances of the factory installing the gutter and awning rails straight and true with the box are less than 0. They're not using laser levels or even string lines, its more of a slap it on by eye process as fast as Amishingly possible and you're going to go insane trying to get the condensate water to go where you want it to. Get some Xanax.:)
Never had an issue with mine, they always run off the extensions at the end of the gutter. Now the fact that the front extensions are right over the storage doors and so always drip on you when you're trying to get something from storage is a different problem, but the water coming out where designed is not an issue.
