Ian10965's avatar
Ian10965
2019 KZ Connect Lite- C201QB – Lippert Frame problems??
I am considering the purchase of 2019 KZ Connect Lite C201QB. Unfortunately this will be a sight unseen purchase. The dealer told me that he would not hold me to continue with the purchase if I don’t like what I see after it arrives. Delivery will be mid June if I order now, well after salt season.
If I decide not to take this trailer then the all too short Atlantic Canada summer season will be pretty well shot for ordering a different TT.
Hopefully with the help of forum members I can at least resolve my biggest concern about this trailer before I order it.
None of these trailers ( KZ Connect Lite 2017-18 C201RB or C201QB) are available for me to look at anywhere close to me in Atlantic Canada. I did look over a Connect 261RB, photos below.
I have read a number of reports of various deficiencies in Lippert frames. I would not be surprised if one part of the Lite designation is reduced metal in the frame compared to the Connect or Spree Connect series.
What I really hope to be able to sort out is how much if any improvement there has been with this problem area for 2018 trailers over earlier models. It would really help if someone could post pictures of the spring mount area of the frame of one of these (C201QB/RB).
I have read posts that suggest that the worst of the Lippert frame troubles may be in the past. Is this correct??
Damage to dual axle spring mounts as a result of the lateral stress during turns seems to be a pretty clear cause and effect. At least this area is easily visible, and I can keep a close eye on wheel alignment as a symptom. If and when the problem appears, I can get the reinforcement done. I have been DIY cutting and fitting steel for decades for hobby /home use. The only skill I don’t have in this area is the actual welding itself.
I do plan to keep this trailer for the long haul. I am 60+, and we plan to make this our only TT after 9 seasons with an 8ft popup. The need for DIY fixing and upgrading is part of my DNA anyway.
It’s the weakness in other less visible areas of the frame that concerns me more. By the time I see external effects of frame failure there may be widespread damage.
The yearly mileage for our trips would be at the short end of the spectrum. We will be sure to go under the GVWR, and never carry much water in the tanks. If not for this I probably wouldn’t even be considering this brand of trailer.
I did manage to get some pictures of a new Connect 261RB, not Lite, at a RV show. See Below. Unfortunately this was before I knew about the frame problems so I didn’t get a clean close up of the flange/rail joint. Its covered with dirt, so I can’ t tell if its welded or rolled. For sure there doesn’t seem to be much if any reinforcement of the spring mounts for a 6800lb GVWR trailer. I tried to scale the metal thickness with a photo editor from the shot with the 14” wheel. Both the flange and the spring hangert look to be 3/16”. At least this would be an improvement over the 1/8” welded up “I-beams” that I have read about.
From the info Lippert frames the narrow flanges look similar to the other welded up “I-beams” that are so problematic.
THESE PICTURES ARE NOT THE TRAILER I AM LOOKING AT. THEY ARE A DIFFERENT NEW CONNECT 261RB.
Click For Full-Size Image.
    Lippert frame failures aren't restricted to K-Z products, my own 2014 Coachmen Freedom Express has a Lippert frame which cracked on both sides just aft of the rear set of tires, discovered when one of the original set of China bombs split and all 4 were replaced with a set of Goodyear Endurance tires. Last October, Forest River - parent company of Coachmen - was ordered to issue a recall for certain models but mine was not on the list even though it was manufactured during the same time period. I left the trailer with the dealer over the winter while he argued with Coachmen & Lippert who would cover the cost of repairing a trailer that was no longer under warranty. Eventually Lippert agreed to cover the cost and metal reinforcing plates were welded in where the frame had cracked and square tube bars added, running from one side of the trailer to the other between the spring hangers to prevent them from twisting. Whether this repair will be effective remains to be seen as I've only so far towed it home but I certainly wouldn't have been a happy camper if I'd had to pay for this repair.
  • Same post you asked at the KZ forum. Too much rust on that unit, been in the salt. Take a vacation and find a dealer has what you want, Like it pull it home.
  • “The dealer told me...” In a letter, email or on the contract itself? Cuzz oral isn’t worth anything.
    My frame is a Lippert. No issues. If inspection of the frame is that important to you drive to a dealer with the unit in stock and inspect. Make an adventure of it.
