Riley01 wrote:
I'm not even sure I would want it after I saw the shower cracks. I'm wondering how much damage will be done pulling the old one out and putting in the new one. ..
I am parting out Lance 1161 to use its parts in Sprinter conversion.
TC is build as huge puzzle and makes quite a challenge to do reverse engineering.
So to remove the shower on my Lance I had to pull outer skin and roofing around the corner where shower is to gain access to screws, who hold the bathroom walls.
Than cut off the drainage plumbing, remove the toilet, tear down all the shower stall support and then I could pull the stall out.
Right now front of my camper is cut off, so I can pull the stall this direction, but there is no way you can fit stall via camper door. Meaning pulling whole roof is probably the easiest way.
Just to give you some ideas how it works.
