FishOnOne
Jun 20, 2019Nomad
gopherslayer wrote:ib516 wrote:FishOnOne wrote:
Here's some more intel on the 3.0 Duramax.
36,000 psi HPFP
Rubber belt drives oil pump. Again at the rear of the engine.
DEF fill port next to diesel fill port.
Diesel fill port looks exactly like a Ram diesel fill port
Link
Only 150k mile life expectancy/design? Seems low. Anyone know what other 1500 series gas or diesels are designed/rated for as far as longevity?
Probably the same 150k. The GM 6.0 probably longer judging by how many 200k-400k trucks are on the road. GMs half ton gassers aren’t exactly the king of reliability and longevity anymore.
So assuming this new diesel lasts way more than 150k miles like their gas engines, why have a rubber belt to run the oil pump. I'm assuming this is a maintenance item that will need to be replaced. Replacement may require engine removal and transmission removal is an absolute.
I do like their DPF/SCR/DOC packaged into one unit close to the exhaust output which should promote better passive regen.
Water pump location appears similar to a cummins.
44,071 PostsLatest Activity: Aug 16, 2026
