Executive45
Sep 22, 2020Explorer III
I bought mine new in 2014 and found it to be an excellent all around toad. That said, every toad has it's faults. Best toad I've had was the Chev HHR which is no longer made. The only difference though was the HHR had more interior room due to it's layout. The Equinox has been a trouble free vehicle with over 41,000 miles on the odometer and around 60,000 towed miles. We have the LTZ 4cyl model and I would get the 6cyl next time around because of the steering. The 4 has electronic steering and the 6 hydraulic. The 4 suffers from the 'death wobble' while the 6 does not. It's been solved with pulling a different fuse but you must add a charging module. ($49) so no biggie. For 2020 I believe they made some minor changes so you should look at the owner's manual to see what needs to be done to tow it four down. The body is the same. You might also look at the Blazer which looks great from the outside. I haven't spent any time at a dealer recently so I can't give you any info on them. I'd recommend the Equinox based on my success with it. Hook it up, put it in neutral, flip the switch and go....Dennis
Click HERE for the 2020 towing guide.
