- TurnThePageExplorerWhile still being quicker too.
- TFL retested the Ram like they said they would and the fuel mileage was at a more believable 33 mpg which is still good. Having said that, the Chevy made 1 mpg better (34mpg) than the Ram and also did 1 mpg better for the towing test.
- wnjjExplorer II
LIKE2BUILD wrote:
Ductape wrote:
Only 100 miles. A bit of foam in the tank, or a small measurement error. No way is measuring the tank level accurate enough for that determination when you’re talking 2.5 gallons in a 33 gallon tank.
True, and I was glad to see the guys at TFLTruck question the results of 40MPG and plan to repeat the test. I do like the fact that they attempt to maintain consistency in how they drive and load the trucks and how they fill the tanks. The idea of filling until the nozzle clicks, wait 30 seconds for foam to dissipate, then fill again until another click is pretty consistent. Is it perfect?....No, but at least they're trying to eliminate variables.
I wonder how empty the tank was before the first fill up? If they had to add quite a bit and it was from underground tanks it’s possible that it expanded some when running the first test and therefore took less on the second pass. Letting the truck sit mostly full before repeating would help remove that factor. - 1320FastbackExplorer
Turtle n Peeps wrote:
"Towing just got cheaper." :B
Until that CP4.2 gives up the ghost... :BGrit dog wrote:
Fish, I've know it all along that you're a closet Ram mafia guy.....
Be careful unless you're planning on coming out, publicly, though.
You're showing your love for them Rams!!
Just simply reporting the facts... But don't worry I've spanked a many MOPAR and continue at every opportunity. :B- Turtle_n_PeepsExplorer"Towing just got cheaper." :B
- Grit_dogTrailblazerFish, I've know it all along that you're a closet Ram mafia guy.....
You're showing your love for them Rams!! - Ram Eco Diesel gets a EPA rating of 32mpg which is 1 less mpg than the GM 3.0 Duramax and 2mpg more than Ford 3.0 Power Stroke.
Link - Grit_dogTrailblazerTrue statements and 40mpg doing 70 on the highway does not seem plausible.
BUT observed numbers aside, I believe more like 30 mpg average is realistic and supported by several years of production of that basic configuration of the Ecodiesel.
The takeaway is yes vehicles are getting better mileage, especially trucks.
I have a 2016 Silverado 5.3 6 speed. In the right conditions it appears to knock down 17mpg cruising. Same config except 8 speed 2019 Silvy I had for a while was knocking on 20 mpg in ideal conditions (70mph, flat road, cruise on)
Not a huge surprise the diesels are 30% better mileage. That’s always been the case.
But as the numbers increase 30% means more. As way less fuel is used compared to lower mileage vehicles.
