specta wrote:
When I bought my truck used back in 2013 I had two choices.
1. A low mileage 2 year old gas pick, or 2, a 5 year old diesel with 150,000 miles on it.
Glad I picked the newer gas PU or I'd be driving a 14 year old truck with 350,000 miles on it.
Mine has the 6.0L with 3.73 gears and I have zero complaints.
My camper only weighs 4000 lbs. With my ATV and trailer total is closer to 12k for everything.
Lantley wrote:
I'm not against higher RPM's or even the noise from a gasser. I'm more pro diesel because I want a relaxing tow with less input from me, the driver.
A gasser requires more input, that means pressing a little harder on the accelerator, letting the truck find the right gear, maintaining the right gear, down shifting as required, holding the gear as required. More effort to descend a steep grade.
A gasser requires more input. Now some may consider that extra input part of the fun and I get that. Sort of like why some enjoy driving a manual transmission.
Personally relaxing and enjoying the ride with little driver input is my idea of idea of a smooth trip.
The diesel takes all the work (driver input) out of the equation. Some may consider me a lazy driver because I want the truck to drive itself with out input from me, to some degree you are correct. That's why I paid more for a diesel performance.
Specta, not bad logic gas gives you more payload for your drop-in camper, but as you state 12,000# total, well out 5er weighs more than that, so an apples to oranges.
Lantley, couldn't agree with you more! Seems our 5er at last weigh is pushing 13,600#, towing with the CTD is so relaxing and quiet. You are not lazy, you just want to arrive relaxed.
Heck I thought I arrived relaxed with the 2001 Ram 2500 CTD with 5 speed manual. I never minded shifting even in stop and go traffic. That said driving the 2016 Ram 3500 DRW CTD, Aisin is way more relaxing.
If towing over 12,000# diesel is the best choice, even with the advent of the Ford 7.3 gas, I got tired of feeding our old 460's.
