danrclem wrote:
ShinerBock wrote:
steve-n-vicki wrote:
I have a 2020 F350 ,crew cab ,long wheelbase, 4 x 4 with 373’s, 7.3 engine, 10 speed
I have about 6100 miles on the truck , I have a towed a flatbed trailer with a 1800 pound zero turn mower on it or a John Deere 1025R tractor with loader and backhoe,I was getting 12.8 MPG,I recently towed a 2003 F250 with a 73 diesel, 4 x 4 crew cab and got the same 12.8, All of it has been flatland Towing,I like the 7.3 and 10 speed
For what I’m using it for, I am told the 6.2 performances similar but at a greater gas burn penalty
From the little driving I have done in the new 7.3L, I would say that it has more low end than the 6.2L. It is not a huge amount, but it was noticeable when unloaded and probably even more noticeable when loaded. It is common for a pushrod engine to have more low end torque than a overhead cam due to how they are designed.
Do you have any seat time pulling with the 7.3 in hilly areas at highway speed. I would think that the 7.3 and the 10 speed would outshine the 6.2 in those conditions since the torque is at a much lower rpm.
No, I only drove both unloaded which is why I said it probably even more noticeable when loaded. The final gear ratios of the 10 speed and 6 speed are very close(.63 on the 10 speed and .69 on the 6 speed) and at highway speed the 7.3L felt like it had more low end to slightly accelerate without needing to downshift. It is not diesel like in any way where you can accelerate rather rapidly with a toe-in of the pedal at highway speeds, but it was noticeable. The 6.2L felt like it needed to downshift for any kind of acceleration in 6th gear even though it has the gear advantage over the 10 speed.
