way2roll's avatar
way2roll
Navigator II
Jun 24, 2020
2020 F250XL 6.2 V8
In shopping at trucks and FW's simultaneously I was deadest on a diesel F250 or 350 (depending on the deal and need). Then I come across a new F250 Xl with the 6.2 V8 and 3.73 ratio. I know very little about the mechanics of trucks and rely on weights etc. I do know that the 3.73 is less favorable than a 4.1 ratio for towing - but how much?
The appeal to this truck - link below - is that the price of this new gas is the same price as a 3-5 year old diesel with close to 100k miles. Granted I am sure there is justification for that, but the long walk around the barn to my question is, is this a decent truck to buy for towing an entry level FW (understanding it depend on the FW)? The ad doesn't get into pin weights etc. Or should I just keep shopping for a used 250/350 diesel?
link
  • rhagfo's avatar
    rhagfo
    Explorer III
    If you want to tow a 5th wheel skip the F250 and just get an F350 with 4.1 and a 6.2 or 7.3 if you are afraid of diesel. You will top out at about 16k tow capacity. An F350 diesel will tow out at about 30k towing, meaning that towing 16k will be easy.
  • The 6.2 is a good dependable engine. I have one and pull a 5th wheel with about a 10,000 gvwr but I haven't ever weighed it to see how much it weighs loaded. I have had it in some fairly steep hills in the eastern US but not over the Rockies. I'm sure it would do the job through the Rockies but I'm sure the altitude would pull it down. It will drop down to 3rd gear through the steepest parts and it runs some fairly high rpms but nothing that will hurt it.
    The only negative I have with it is the fuel mileage unloaded. If you're going to drive it very much unloaded be prepared to spend a lot on fuel. It does not get great mileage loaded but I figure that's to be expected with just about anything.
    It would really depend on how much you want to tow as to how good it will do. If it were me and I were buying new I'd probably buy a 7.3 F-350 if I wasn't pulling a huge trailer. That's just me and everybody has a somewhat different opinion.
    Can you get a 10 speed behind a 6.2. If you could that would help.
