JD5150
Sep 29, 2019Explorer
Grit dog wrote:jimh425 wrote:SoonDockin wrote:
Where did you find that number? I am looking to see what max payload might be with that engine.
This article says 7850 but I don't know what trim or engine.
https://jalopnik.com/heres-how-you-could-actually-use-the-new-ford-super-dut-1838498804
Certainly it's a reg cab XL 2wd dually. About the only way to stay near 6000lbs.
The question is, do they really have springs to hold up that much weight? Seems a bit optimistic, or it rides like the axle is just bolted to the frame.
Most likely is the 2wd reg cab. Here is a 2019 4wd reg cab, 6.2 gas rated at 7230 max payload listed at a car dealership in Kansas. You will have to scroll down and look under features then scroll down in that box and you will see the max payload 7230.
2019 F350 Max Payload 7230
