bwlyon
Mar 16, 2019Explorer
Fog lamps are a yes, we like them. Pedals are a yes if your wife has short legs. E locker yes especially if you plan on any off road activity. 4.30 rear axle ratio NO, 4.10 is plenty. We have 3.73 in our Ram 3500 and get by just fine; however, I run in 4th gear on the 2 lane roads and 5th on the interstate to stop all the hunting gears in the hills with the 6 speed Automatic. If I had to order a new one I’d get the 4.10. I’d go with the Laramie for easy to clean interior and likely available dual power seats along with heating and cooling. E start YES, very handy. Go ahead and get the AT tires if you like; however, they may not suit your taste so choose wisely. The Reverse Sensing will go nuts with the camper on the back, on the Ram it’s push a button and it stays off, not sure on the Ford. Yes to the camper package. Take your time and order it the way you want it. Trying to find a truck on the dealer lot with the specs you want with a gas engine is like finding a needle in a haystack. We got lucky and only had to bend on the color, and found used Ram 3500 gasser with the right specs other than color.
