Not a ford comparison, but works with any brand. , Noted, empty wieghts based on how many options you have, cab sizing etc
3 of us had 05 dually crew cab GM trucks. On weighed 7200 lbs, a fairly stripped rwd model. Mine 7400 lbs, an LS 4wd. The third was over 7800 lbs, 4wd full leather pkg etc.
Even a higher gvwr might not be your friend. Saw a 2018 F250 advertised the other day, has a 10k gvwr. Says it weighs 6200 lbs empty, payload 3800. My current rwd gm c2500, gvwr 8600, weighs 4800 lbs, payload 3800 lb. My 05 dually listed above, 11400 gvwr, 4200 lbs of payload.
Any truck, the options alone can add over 2000 lbs to any particular body style.
If you looking at brochure wts, unless you have a truck like my c2500 with three options vs base, it will weight more than brochure weights!
Trust ALL of us on that!
Marty
Edited to fix phat thumbs from phone posting this morning!
