burningman wrote:
I’m betting a lot of people get into trouble with that.
Load that up and hitch a trailer behind and you’re over 26,000 real quick!
Around here the DOT has been cracking down on all the 350/450/550 trucks with trailers driven by people without a CDL.
But it’s a way to one-up the guys using an F550 for a camper.
Actually, under DOT rules, 20K is the break point but RV's are exempt.
I run DOT numbers on my F350 because the truck is used for commercial (farm) use pulling a gooseneck.
That also means CDL which I have and a logbook which I also do when I'm using the truck for farm use.
The motor carrier enforcement officers around here (Michigan) also are bagging pickup trucks right and left for non-compliance and first time fine is $150 bucks. Second offense is 150 bucks plus they shut you down.
DOT numbers are free and available online through their website... https://www.fmcsa.dot.gov
There are specific regs that pertain to number height and placement. I bought my vinyl stick on numbers online, I think 2 sets were 3 bucks.
I put them on both my rear doors (have 4 door truck), just below my farm name.
The problem arises because, unless the camper is on the truck 100% of the time, the truck can be used for other purposes which may or may not be a commercial purpose. RV's are exempt because the RV is permanently attached to the chassis.
Mine is not and I have a commercial use so I run DOT numbers. That also means you are subject to all DOT roadside inspections and you must go through all weigh stations. Compliance is easy-peasy so why chance it. I sure as hell don't want to be fined, nor do I want to be taken out of service when I'm running farm stuff.
You also need a current, valid, DOT medical card. Have that too.
