Bedlam
Mar 08, 2019Moderator
2020 Ford F600
Ford is introducing a smaller Class 6 chassis cab truck next year called the F600. It will share many of the components of the larger F650 but be the same dimension as the F550. This 22K lb GVWR vehic...
Kayteg1 wrote:burningman wrote:
I’m betting a lot of people get into trouble with that.
Load that up and hitch a trailer behind and you’re over 26,000 real quick!
Around here the DOT has been cracking down on all the 350/450/550 trucks with trailers driven by people without a CDL.
But it’s a way to one-up the guys using an F550 for a camper.
Ridgefield Port of Entry is famous for harassing drivers for generations, what is different story, but I think you are exaggerate the 26,000lb sets with campers.
But regardless, once you register the truck as RV, you have no longer 26k limit, so my guess is, that now we can expect 8000 lb campers with 5 slides? :E
BTW my F350 dually has about 22,000 lb on tire ratings, so what is big deal?
