Huntindog
Feb 18, 2019Explorer
blt2ski wrote:But far steeper than what 99.9999999% of Rvers will ever see. Towing or not. Not really an issue in an RV forum.
If these 10 spds are like the 8 sp auto trans in MB's. At least the ones My wife has brought home as loaner for her ML, they do not always start in 1st gear. I've only found them using first when on a grade in the min 10% grade range. The hill I know it is used, might be steeper, more in the mid teen range.
With that said, a 12% grade in the tow test, is a pretty minor grade! Altho 1.5x steeper than a max on an Interstate.....still not that steep.
Marty
As an aside.... I read where many/most 1/2 ton 4 wheel drives are now all wheel drive. No transfer case, and no low range..... This is something that SHOULD be talked about on this forum to bring up the awareness. Back when I towed with a 1/2 ton, low range was certainly used quite a bit when jockeying into a campsite.
44,070 PostsLatest Activity: Jul 01, 2022
