Huntindog wrote:
I understand precisely what you are saying.
One question: Does Ford do SAE testing procedures with a SAE witness or not?
If not, then you can dis the SAE standards all you want. The Fact would be that Ford tests without any "benchmark" standards. IOW, They can make up their own test standards.
Using a witness does not matter in what I am talking about since none(zero,zip, zilch, nada) of the SAE tests is sustained power. It is only short burst power. So having a witness has nothing to do with it.
Also, the tests standards(witness or not) have the same correction factors. Ford or any manufacturer could use the best correction factors today without a witness and then use the very same best correction factors next year with a witness and it would still be legit. A witness does not mean squat in this because it is legal to do witness or not, and a witness would still sign off on using the best correction factors because it is within the test parameters. I don't think you understand how the process works because you would not be saying what you are saying if you did.
