Cummins12V98
Apr 08, 2020Explorer III
4x4ord wrote:Cummins12V98 wrote:4x4ord wrote:
Ford requires the transmission fluid be changed every 150,000 miles. How often is the fluid to be changed in the Aisin?
30k fluid then 60k filter and fluid. I’m thinking this is to do with the use these AISIN’s see in Medium Duty applications.
I will say there is no way in HE11 I wold go 150k towing what I do with a new Ford.
You gotta get a Ford. There is no way I'll keep my truck long enough to require the tranny fluid to be changed. I change the engine oil every 25k km and add fuel and windshield washer fluid as needed. That has been it for maintenance other than tires.
If I were in the market for a Gasser It could be a Ford, Diesel......NO!!!
44,066 PostsLatest Activity: Oct 04, 2013
