ShinerBock
Apr 11, 2020Explorer
FishOnOne wrote:blofgren wrote:ShinerBock wrote:FishOnOne wrote:ShinerBock wrote:
They would rather be reliable than a hot rod.
I think we know better than that since Cummins in the Ram trucks has been on a constant battle in the power war. And from a total engine and emissions system the the cummins is not the most reliable and now that Cummins adopted the CP4.2 pump, hydraulic lifters, and I'm now hearing the 19-20 cummins trucks are using oil it's reliability will not improve.
Not Cummins. Their horsepower numbers have hardly gone up in the last ten years. Their torque has, but you can reliably make that while still being conservative. I know Ram would like Cummins to be more aggressive with their power numbers which they easily can with a more aggressive turbo and tuning given that it has the largest displacement of all three, but this is not the route the usually take.
Although the mention of the new CP4.2 plays into what I am saying. Ford adopted the CP4 just about as soon as it was out in order to increase power numbers. Cummins waited a while for all the problems to be fixed. Also, the use of the CP4 was more of a requirement due to new NOx limits rather than wanting to use it. The CP3 does not have enough pressure to do so. Hydraulic lifters have become more reliable because you don't have to do valve lash adjustments every 150k.
This, I feel, is the difference between Cummins and Ford. Ford will use as much new tech available to be the "best in class" (so will Ram) and fix things as they go while Cummins waits for all of the kinks to be worked out before putting it on their engine(aside from emissions stuff which was forced by the EPA). This is why the PSD changed so much in the last decade with things such as the turbo, intercooler coolant routing, pistons, and so on while the Cummins has remained mostly the same through the past decade. Not wrong, just different ideologies in what they think is important. To some, Ike times matter, to others, having reliable parts and not being a guinea pig to new tech does.
I am already hearing things about the new 2020 trucks in our fleet and from our 9 dealerships, but that is to be expected with any new design.
Very well said. When I was looking to get out of my 2003 F-350 6.0L diesel in 2014 after way too many issues, it was becoming apparent that the Ford 6.7L was experiencing some concerning issues. As much as I was a die-hard Ford guy, I went and looked at some Ram/Cummins and ended up buying the truck in my signature, which my wife's family said I should have done years ago. Now that I have had the truck for some time, I have to agree. :B I really don't care about being to the top of the hill first, but I do care about reliability which Cummins has provided for many years now. The 2020 Powerstrokes are definitely impressive, but I'll be even more impressed when they reach 3-400k miles with minimal repairs......
You do realize that the CP4.2 in the Cummins is overdriven compared to the Ford. So the CP4.2 in the Cummins turns at a higher RPM so we'll see how that turns out.
Actually this is false. The new CP4 has an updated cam that allows it to pump up to 39,000 psi. Cummins is only using it to 29,000 psi while still using solenoid electric injectors. Ford on the other hand is using it up to 36,000 psi along with piezoelectric injectors which is one reason why they are able to hit such high power numbers. Cummins can easily crank up the CP4 they are using to max output to increase their power numbers, but as I said above, that is not their focus.
BTW, CP4.2 does not mean it is a second generation. It just means that it has two pumps. The single pump version like what is on me diesel car is a CP4.1. The technical term for the new CP4 is CP4-27 as in 2,700 bar or 39,000 psi which is its max output.
44,066 PostsLatest Activity: Apr 16, 2026
