Cummins12V98
Apr 12, 2020Explorer III
"Cummins12V when Cummins was using the CP3 it was a main talking point of yours as one of the major advantages of the RAM. Now that Cummins has a 4, you ask for proof its not a POS. You never accepted that in the years before. A CP4 was poop, plain and simple. I think at its worst the 4 had what...2% failure rate in FORD and GM? Costly as hell if the warranty doesn't pick it up, but a rather small failure rate. Yet you played it like a fiddle. Now you take the exact opposite side when RAM takes the CP4. Consistency is a major part of credibility."
Sorry you have NOT seen me ANYWHERE say the CUMMINS CP4 is great, dependable or reliable. All I have said is I have seen NO Ford or Cummins CP4 failures in the last two model years. That is why I was ASKING if anyone had seen any failures. Ford pumps seem to be doing fine for even longer.
During the time of all the Ford and GM failures I sure did mention the dependability of the CP3.
Would I buy a 19 or 20? I was planning on a 20 but honestly I like the looks of mine much better so I will hold onto it for a while longer. Not buying a 20 has nothing to do with the pump as like I said it appears to be fine. If I did buy a 20 and the pump failed it would get covered for the first 100k.
44,066 PostsLatest Activity: Apr 15, 2026
