FishOnOne wrote:
Marine0311 wrote:
Just purchased a 2020 Silverado 2500 with PUCK system for hitch placement. Told dealer that I would be using it as a tow vehicle and was assured that this vehicle would be all I needed. Turns out that Chevrolet moved the puck system back behind the rear axle for the 2020 year model. If anyone out there has one of these trucks with PUCK system, what hitch are you using? I've contact several hitch manufacturers and they say they are aware of the issue, and are designing new hitches. Can't find anyone yet at Chevrolet to tell me why they moved the location. The way it is now, the weight of the king pin will be just aft of the rear axle, a condition which I would think would raise the front end some. If I had to do it over again, I would of bought a truck with out the PUCK system.
Actually GM moved the location of mounting the axle to the leafs with an offset but the hitch is still mounted in the center of the leaf springs. I think this change was done to reduce squat with a load and improve ride quality without a load.
So they lengthened the cab and then shorten the wheelbase to keep it close to the same as earlier models?
