MFL
May 30, 2021Nomad II
If you remove the wet insulation, I would replace with whatever width extruded board insulation that is a good fit. Once done, you should not have an issue if the board insulation gets wet in the future. At some point, we all tow in a hard rain. You can even piece in the extruded where necessary, and could be glued to the floor, depending on the design??
Jerry
Jerry
