colliehauler
Sep 29, 2020Explorer III
2021 Ford F-150 hybrid
Seen it can tow up to 14,000# and the electric motor can act as a generator producing between 2.4-7.2 kilowatts depending on configuration. Sounds like a good match for RV owners.
Groover wrote:bikendan wrote:Groover wrote:
"This model is also capable of hauling a 3325 payload"
I will be much more impressed if the payload package is more obtainable and can be combined with the higher towing ratings. It has been almost impossible to get for the last 6 years and required seemingly unrelated compromises if you did special order it.
Yep, I'm more interested in the real world payload capacity numbers, NOT towing capacity numbers. Especially with a big heavy battery in it.
It won't have a big heavy battery. I would be surprised if the lithium battery in it weighs 30lbs. I would like to see at least 4 times that much battery.
