colliehauler wrote:
Isn't the battery/electric motor more of a temporary boost for like climbing a hill or passing another vehicle?
That is part of my beef with this tiny battery. The battery will probably make a good impact on the EPA mileage test for an empty truck but I would like to have a battery makes an impact when towing a fairly heavy trailer. Also, a mode that enables you to charge or deplete the battery (especially one this small) in anticipation of making a major hill climb or a descent. Batteries also charge slower than they can discharge so your regen will be limited by battery size.
Finally, this truck is advertised for use as a 7.5Kw stationary generator. It doesn't make a lot of sense to have to run an engine this size continuously to supply 2 or 3kw. Put in a big enough battery that you can run the engine awhile at a higher output then shut down for an hour or two.
Finally, there are tax credits available for batteries of 5Kwh so at first they really wouldn't cost the consumer anything. My guess is that Ford is saving those credits for vehicles that will try to compete with Tesla.
