colliehauler
Sep 29, 2020Explorer III
2021 Ford F-150 hybrid
Seen it can tow up to 14,000# and the electric motor can act as a generator producing between 2.4-7.2 kilowatts depending on configuration. Sounds like a good match for RV owners.
jdc1 wrote:
Here's what the big three missed:
They should have built this hybrid like a Chevy Volt/Honda Clarity. But, instead of a gasoline engine, a 2.0 liter diesel generator. See, Clarity's and Volts's are electric vehicles with gasoline generators. The big three could have easily configured a 400hp electric set-up like the Volt/Clarity. The motor in that set-up would last 2-3 times longer than a standard vehicle, not having to do much more than generate electricity. Imagine your truck having 400hp without having to get up to speed or wait for the turbo's to kick in. That's 400hp ALL the time, whenever you need it. No slowing down on 6% grades. Regenerative charging on the way down that same hill. Biased? Yep. I own a couple of hybrids. I know just how wonderful they are. Getting 80mpg from my plug-in Prius is like sipping a fine wine.
