colliehauler's avatar
colliehauler
Explorer III
Sep 29, 2020
2021 Ford F-150 hybrid
Seen it can tow up to 14,000# and the electric motor can act as a generator producing between 2.4-7.2 kilowatts depending on configuration. Sounds like a good match for RV owners.
  • "This model is also capable of hauling a 3325 payload"
    I will be much more impressed if the payload package is more obtainable and can be combined with the higher towing ratings. It has been almost impossible to get for the last 6 years and required seemingly unrelated compromises if you did special order it.
  • jdc1 wrote:
    Hopefully it's a plug-in version, having the ability to travel 25 or more miles on electric only.
    Nope. Not nearly battery to even consider that.
  • It appears that the hybrid is good for 12,700lbs and the 14,000lbs rating is for the non-hybrid drive train.
    Hybrid, 12,700lbs
    Standard truck 14,000lbs
    Until I see it in the towing handbook I am going to take the numbers with a grain of salt.
    The HO version of the 3.5 used in the Raptor and Limited is missing from the charts but the standard version is up to 400hp while the hybrid is at 430hp. Presumably for just a short burst though with only a 1.5kwh battery. I would like to see it with at least a 10kwh battery.
  • Dadoffourgirls wrote:
    The hybrid will be able to tow up to 12,700 pounds and haul up to 2,120 pounds, Ford says.
    The article said (14,000# tow rating a 800# increase over the 2020 model. This model is also capable of hauling a 3325 payload).
    Just what I read the in news so take it for what's it worth.
  • jdc1's avatar
    jdc1
    Explorer II
  • The hybrid will be able to tow up to 12,700 pounds and haul up to 2,120 pounds, Ford says.
