- ShinerBockExplorerI will say that the Denso HP3 and HP4 pumps are not without their flaws either. We have had some failures on them as well in the Hino(Toyota) medium duty diesel trucks. There are even a few TSB's out for them. The reason why most probably don't here about them is because Denso does not have that big of a market share especially in the personal vehicle market. Even on the commercial side, diesels powered by Denso fuel systems is very small.
I think people need to understand that these pumps are pumping at very high pressures. Just as with horsepower, the higher you go, the likelihood of component failure increases as well. For all you wanting and bragging about more stock short burst power, this is what you get because the manufacturers have to increase pressure every time they have a major power increase in order to stay emissions legal. You can't have your cake and eat it too. As with VG turbos and other components, you are starting to sacrifice reliability for the pursuit of more power on engines that also have to meet emissions.
Hence the reason why I would rather the engine makes have lower power, but use more reliable parts. I can easily add power after the fact that will make the truck more reliable by ditching things like electronically controlled VG turbos and so on that are less reliable than their mechanical counterparts. - IdaDExplorer
blofgren wrote:
If I were shopping for a new diesel truck right now it would almost certainly be a GM because they switched to a Denso pump.
Ditto. In fact this very issue was one of the big reasons I bought a Ram in 2015. While it's great that the CP4 has improved since it was first introduced, it's still a flaming turd as far as I'm concerned. - ShinerBockExplorer
Cummins12V98 wrote:
"however pump failures are less common in Canada"
What do you base that on?
I would have to ask the same too. You would have to at least have total failures data versus total diesels with said pump sold both countries which I don't know how someone would have. If it is based on the factor of just not seeing as many failures in Canada over the US, one would have to also consider the diesel truck sales volume of each country.
I know that Texas and California diesel fuel regulations are better than the US standard, but I don't know much about the Canadian standard. I would have to look at and compare the scar and lubricity ratings for both. - Cummins12V98Explorer III"however pump failures are less common in Canada"
What do you base that on? - 4x4ordExplorer IIII don’t blame you, however pump failures are less common in Canada. I think our fuel must provide a little better lubricity. I think I’ll buy what I want based on price and take my chances on the pump. In the unlikely event that my pump fails I’ll hope it’s cornered under warranty,
- blofgrenExplorer
4x4ord wrote:
Does Cummins use the same pump as Powerstroke cuz I just read that the Cummins has a 29000 psi fuel delivery system where as Ford claims they went to 36000 psi for 2020? I think both use the Bosch 4.2. How does that work?
Edit: Upon doing further google searches I found evidence of a CP4.2 pump failure in a 2020 Ford. Even if the pump has been changed for 2020 it sounds as though it’s still a POS. It seems almost unbelievable that Ford would stick with Bosch even if the number of failures are rare the damage these failing pumps do to the Powerstrokes reputation has got to be costly to Ford.
I'm not 100% certain, but I believe it is the same pump. They have made changes to them since they first appeared in the Ford and GM in 2011 which has improved the reliability, but it is still a crapshoot and is one of the major reasons I bought a Cummins with the trusty CP3 pump. I can't say I'm surprised that they are failing on the 2019 and up Cummins engines.
I work with a guy who had it happen on his 2012 F350; the truck was just outside of engine warranty mileage and Ford was going to stick him for the entire cost of the repair so he traded it while it was still in the shop on a 6.2L truck. He was not happy about it but was caught between a rock and a hard place. It may not be as common of a problem that it once was, but it still really sucks if it happens to you, especially if you end up footing the bill. If I were shopping for a new diesel truck right now it would almost certainly be a GM because they switched to a Denso pump. - ShinerBockExplorer
ford truck guy wrote:
WOW.....
almost 15 pages of this banter back and forth !:S
Lots of banter for sure! With most forum sections being slow, tow vehicles still keeps somewhat active.
I still read much of this back/forth, and have to say, that Shiner has a lot of knowledge to share, and shares it in a respectable way. Just my observation, not taking anyone's side of the issues.
Jerry
TRUE Jerry,
I have always looked at BOTH shiner and 4ford, and MANY others here as A lot more knowledgeable than I ..
It IS interesting to read each post...
Thank you both! The only reason why I know a thing or two about this stuff is because it has been apart of my profession for the past 25 or so years. I am 100% certain that if I stepped into your world and what you did as your life's profession, I would be learning a whole lot of information that I didn't know from the both of you. ford truck guy wrote:
WOW.....
Jerry
TRUE Jerry,
I have always looked at BOTH shiner and 4ord, and MANY others here as A lot more knowledgeable than I ..
WOW.....
Jerry
TRUE Jerry,
It IS interesting to read each post...- MFLNomad II
WOW.....
Jerry
44,030 PostsLatest Activity: Feb 06, 2025
