- mkirschNomad IIWhere's the 8000lb payload number coming from?
20% of the 40,000lb trailer? You all realize that 20% is not a required minimum for a gooseneck, right? Balance the load over the trailer axles, 40K no problem. - Cummins12V98Explorer III
larry barnhart wrote:
Cummins12V98 wrote:
I have 80 gallons.larry barnhart wrote:
FishOnOne wrote:
Wow... Towing just got easier!
Not if diesel isn't available. No towing maybe.
chevman
Larry U have SUM DEEZul I can bARriE???
chevman
Ill be over the hump shortly. - larry_barnhartExplorer
chevman
chevman - Cummins12V98Explorer III
chevman
Larry U have SUM DEEZul I can bARriE??? - larry_barnhartExplorer
chevman SoonDockin wrote:
You know that extra power will cost you a ton. Saw a 12k price add on for picking the HO Diesel. That's over the standard diesel when I configured a F450. Hard to pick it just for bragging.
Negative... the new HO diesel is $12,495.00 over the cost of a gas, the older 6.7 is $9,995.00... for a difference of $2500.00 between the 2 diesels- Bionic_ManExplorerImpressive numbers. I bet it won’t be long before you see a bump in published numbers by GM and RAM.
I’d like a report from someone comparing the standard output vs Hugh output. I wonder if you can tell the difference by the seat of your pants? - Might be true but the F450 is only available with the Diesel, so if it is an error, they should change it soon!
I went on Fords site and after verifying the F450 does raise the price by $12495 when checking HO started a chat with them. They should have the issue resolved soon. - 4x4ordExplorer III
Im certain that is an error on their build and price website. The HO is still pricey for what it is but it’s a $2500 charge over the regular 6.7 diesel and I think it’s supposed to be $12,495 price increase over the 6.8 liter gas engine. - You know that extra power will cost you a ton. Saw a 12k price add on for picking the HO Diesel. That's over the standard diesel when I configured a F450. Hard to pick it just for bragging.
44,053 PostsLatest Activity: Jan 06, 2022
