Bionic_Man
Sep 28, 2022Explorer
valhalla360 wrote:FishOnOne wrote:afidel wrote:
Disappointed they didn't bring PowerBoost to the SuperDuty this year, it's a feature I'd love to have in my next truck but I won't be buying another half ton, next truck will be a 1T SRW.
The F150 PowerBoost benefits are really limited to city driving and there's really no advantage with towing IMO.
I didn't watch the videos but saw an article a few days back (can't find the article now).
The new 6.8L is supposed to be 400hp and 450lb-ft. The 7.3 is 430hp and 475lb-ft...hardly seems worth the trouble to have both.
Has anyone heard a suggestion of what Ford's logic is?
While a modest turbo on either (assuming the block was built for it), would be great. Problem is if they put out a big block turbo for the super duty line, I would assume it would have at least 500-550hp and probably north of 550-600ft-lb of torque. With the turbo, you could dial back the RPM while still putting out lots of power. That would make it very competitive against the diesels.
It becomes a marketing problem. How do you talk buyers into the $10k upgrade for the diesel if a gas 6.8L turbo can go toe to toe with the diesel in the toughest conditions for say $3k?
I also don't understand the logic for two engines that are so close in rating. If I were guessing, I'd say that maybe the 6.8 is built to accommodate some sort of hybrid upgrade and the 7.3 is not.
As for the turbo big block, the answer is also MPG. In that a turbo BB would make the old 8.1l seem miserly. It would likely get less than 5 MPG towing. Which is why you haven't seen the 5.0 receive the "eco boost" treatment either......
