trailgranny50
Aug 12, 2015Explorer
20th century upgrade.
OK,so I bit the bullet into 20th century buying an onboard battery for our old Shadow Cruiser. It will have to set in the wheel well by the door at the floor up front. Got a group 31 AGM for long warranty best function, I hope, for our needs. Haven't changed out the converter for the new three phase battery minder yet. Calls to mind the wiring. Know to reconnect everything to proper breakers/fuses but have burning need to know how to include the battery wiring in this process, where it connects to converter. Haven't had an onboard battery in so long I've forgotten how to hook that in. This converter charges the battery in bulk mode, standard and floats it for storage. Does the automatic switch from shore/gen to 12v. Don't want this back feeding into truck batteries or via versa, right? We simply unplug truck whenever not using those batteries now, same procedure after install? Is a battery cut off switch necessary and if so it would go in line right before the battery? So many questions, sorry. Not tackling this til next week so time to map out procedure. Had issue with back up camera on constant hot, not enough consistent power from first attempt but great with direct connect to battery. That I can handle as just running extension cable from Garmin and direct bolt onto battery posts. Going to use 8 gage from battery to converter, only an 18" run for that. So there ya go guys. Any, and I mean ANY input appreciated.
