- zackyboy3rsExplorerI am leaving Tuesday and heading to ocean lakes. I do not have the water hose connected. TT is sitting my yard with electric plugged in and gas on. Water heater is not drained. Water in all tanks.
- wmosesExplorer
powderman426 wrote:
For about $3 worth of rv antifreeze and fifteen minutes time, I would winterize. But thats just me.
:h
They are going camping. How can winterizing help? - Rolling_CondoExplorer IIDouble post. Deleted.
zackyboy3rs wrote:
Leaving Tuesday for MB but Sunday night lows are suppose to be lower 20's. Will running an electric heater & furnace be enough protection? I do have enclosed underbelly. What if I were to turn on hot water header? Would that cause any harm? Help any?
I'm headed for MB myself tuesday. Been getting the trailer ready today. Had planned on connecting water today but not with it going down to 24 here. - LakeNExplorerWe are in a similar situation.....we drained all water and blew out lines a few weeks ago. Better to be safe than sorry. Will travel south & then rewinterize in January.
Good luck & here's to warm weather! - I_am_still_waynExplorer
Golden_HVAC wrote:
Hi,
You do need to keep the water heater above 32F all the time...If you where camping, you can turn on and off the water heater, just making sure it stays above about 45F,
Fred, is it 32 degrees or 45 degrees? - powderman426ExplorerFor about $3 worth of rv antifreeze and fifteen minutes time, I would winterize. But thats just me.
- Opie431ExplorerIf you have left your water on and anyone gets up at night they should run the water at each faucet and flush the toilet. Same should be done just before you go to bed.
- zackyboy3rsExplorerThanks. I just wanted to double check & get y'all's opinions.
I have my camper plugged up at all times. Electric water heater (and gas). The high the next day going to be 45-50 degrees. - IvylogExplorer IIIThe temps during the day are going to be well above freezing so travel will not be a problem. In addition to turning the water heater on at night, I'd open all the cabinet doors under your sinks.
