Reality_Check
Aug 28, 2014Nomad II
bigfootford wrote:joe b. wrote:
Instead of using an extension, I have seen RVers extend the trailer tongue, to the needed length. Recently I was looking at a posted blog where a couple took their TC round trip from Michigan to Alaska, pulling an enclosed cargo trailer with a motorcycle in the trailer. He had the trailer tongue extended and said it all work fine for the trip.
I can totally jack knife this trailer 90 deg and not touch the camper.
We added 1.5 ft. Basically duplicated the tongue on a Uhaul 5x8 single axle trailer except for the bend upward. 3/8" 2x3 tubing.
Jim
Extending the tongue is under rated and rarely done, but it's easy.
We're running 28" and 48" extensions, and I have one trailer that still needed the tongue extension. It's a longer 10k, and I had to add about 20" to be able to jack knife it safely with the camper on.
A-Frame or not, the extension's are easy and pretty straight forward.
I suggest that the OP's problem is fairly light duty and a single extension is probably completely adequate. Most boats can jack-knife without any problem as is.
44,066 PostsLatest Activity: Mar 14, 2015
