Grit_dog
Aug 28, 2014Trailblazer
Mello Mike wrote:
If you're towing a heavy load with a heavy tongue weight then I would buy a Torklift Superhitch. However, if you're going to tow something light or tow a vehicle 4-down then a simple 2 ft hitch extension will be more than sufficient.
This.
I rolled up the Alcan from Seattle to Anchorage last year during frost heave season = terrible roads with a 12" ext on my OE Dodge receiver towing about a 5klb trailer with pretty good tongue weight estimate about 800lbs. No problems.
Used a 24" extension all winter to clear my sled deck with my 2 place enclosed trailer max weight about 2500-3000lbs not much tongue weight. Again lots of ugly road conditions without issue.
Trailers pulled the same by the way. I've inspected the receiver a couple times and it looks ok. No cracks or bending.
I wouldn't reccomend it with older or 1/2 ton truck hitches at all and even I'll admit it's not the "right" way to do it.
44,066 PostsLatest Activity: Mar 14, 2015
