sonuvabug
Nov 06, 2014Explorer
Bedlam wrote:
... snipped ... I think that setup will work fine for the amount of hitch weight you are applying ... My hitch weight is 2-3x more than yours and I have not seen a better extension system than TorkLift's for those of us that pull heavy trailers.
I absolutely agree with you and if we had the need, your set-up is the "go to" one. I realize we are limited to our 3,500 lbs. rated cargo trailer and our 2,000 lbs. rated utility trailer due to the 350lbs. tongue weight maximum. However, that is all we ever envision pulling behind our truck and TC as we are not boaters etc.
If I remember correctly, the SuperTruss extension required the TorkLift hitch receiver set-up to be installed on our truck in order for it to work. The two units would have run us over CDN$2,000 ... not worth it to us for our application.
